Configure the required SPBM and IS-IS infrastructure, which includes the creation of SPBM B-VLANs.
Create the C-VLANs and add slots/ports.
Enable IP Multicast over Fabric Connect globally.
If no IP interface exists on the VLAN, create one. The IP interface must be the same subnet as the IGMP hosts that connect to the VLAN.
Use this procedure to enable IP Multicast over Fabric Connect on a brouter port IP interface. The default is enabled.
To configure a brouter port for a VRF with IP Multicast over Fabric Connect, see Configure IP Multicast over Fabric Connect on a Brouter Port for a Layer 3 VSN.
You cannot enable IP PIM when IP Multicast over Fabric Connect is enabled on the VLAN.
The switch only supports IPv4 addresses with IP Multicast over Fabric Connect.
SPB Multicast Field Description
Use the data in the following table to use the SPB Multicast tab.
Name |
Description |
Enable |
Enables or disables SPB Multicast. The default is disable. |
